What clutch cable do i get??
Moderator:Scirocco Register
gnrsoul
fill in the right answer:15
Post by gnrsoul » Fri Sep 15, 2017 2:59 am
Looking for some help there is a few different types and length when i have been look them up to buy
I have a early 83 scirocco but has a kr 16v fitted dont know if that makes any difference or not but if anyone knows the correct cable would be much appreciated
Cheers chris
fill in the right answer:10
Re: What clutch cable do i get??
Post by GTXTRA » Fri Sep 15, 2017 7:29 am
Right hand drive car?
I'll check mine at weekend for a part number.
gnrsoul
Post by gnrsoul » Fri Sep 15, 2017 11:56 am
GTXTRA wrote:Right hand drive car?
Yeh right hand drive and cheers
gnrsoul
Post by gnrsoul » Sat Sep 16, 2017 2:10 pm
Would this be the correct one?
http://www.ebay.co.uk/itm/401292955555
Post by GTXTRA » Mon Sep 18, 2017 8:12 am
Possibly not, that's quite short.
If you do a search on here there is a historical thread re 1490mm cables being the correct ones for dx engines cars.
NLA of course.
Post by GTXTRA » Mon Sep 18, 2017 7:20 pm
Shows part number k00154721335
Fitted in 2010.
Post by mark1gls » Mon Sep 18, 2017 11:02 pm
Not much room around that clutch cable at the gearbox end....
Post by GTXTRA » Sun Sep 24, 2017 8:26 pm
And as it happens VHW sell one with same part number.
https://www.vwheritage.com/154721335-cl ... hd-1-5-1-6
I'm just not sure what your manifold set up is.
And yes Mark - it's a busy little bay but the 16v comes with a guide frame for the end of the cable where it meets the gerbox.
