Inner wing repair - advise needed
Moderator:Scirocco Register
skirocco
fill in the right answer:15
Post by skirocco » Thu Jul 08, 2021 6:04 pm
Hi - does anyone have tips for repairs to an inner wing on the Mk1.
Thanks,
Mike.
PS - I have windows trim for a Mk1 for anyone interested.
Village Idiots
fill in the right answer:10
Re: Inner wing repair - advise needed
Post by Village Idiots » Fri Jul 09, 2021 9:57 am
What is the damage?
skirocco
Re: Inner wing repair - advice needed
Post by skirocco » Fri Jul 09, 2021 3:09 pm
It is up high where the clip for the fuel filter attaches to the inner wing and runs out either side of the clip.
Village Idiots
Post by Village Idiots » Sat Jul 10, 2021 8:08 am
If it's badly rusted, I would cut out all the rust with an angle grinder and weld in some new steel. For using an angle grinder and welding around there you need to move all parts of the fueling system in that area
from the car and clean up the area around using a wire wheel on an angle grinder. Then good quality base coat, eg Electrox, spray body colour and underseal on the outside. If rust isn't too bad, a good clean up back to shiny metal inside and out.
